Got A Problem
Jeza
Hi all,
I have a problem, i am current running the new echo cnc'd hub on an old levelboss mod the one with black stickers, anyway everytime i tighten up the wheel it is all centred then after a kick(to back wheel invoving a fair bit of force) it moves across to the opposite side of the drive side, i have added washers with grip hoping that would help and also i have tried doing it up super tight also no luck!
Anyone got any ideas??
Really annoying, making each ride annoying and i really want to ride but feel that there is no point as i get considerably annoyed with the brake squeeking as it has moved across, i run plazmatic pads so noisey pads anyway.
Thanks Jeza
By the sounds of it try the following
1 ) Tighten the snail cam to the next tightest setting, so that when you pedal its still pretty tight
OR
2 ) As you start setting it up, put some pressure on the pedal, then if it jumps out again, correct the tension, THEN tighten the wheel nuts/bolts
Other than that Im stumped :S
EDIT: my god im talking sh!t tonight lol
Edited by PaRtZ
