Can You Make A 10mm Axel Frame Into A 14mm
trials_king_2005
Hi, My mate Python_Rider (tom) has a python(obviously) and has a 14mm axle in it. He Filed down the dropouts a little bit but looks and rides just as nice, just means getting when getting new axles could be harder. :S Doubt it though,
Hope i helped
Jay
As mentioned, either file away the frame dropouts (make sure its the same each side, other wise the wheel will not go in straight, or file/grind flat spots on the axle.
i think flatting the axle would be better, as you could use the wheel in frames designed for 14mm and 10mm axles, and you wont wreck your frame if you ever change the wheel!
as suggested allready, you can either grind the axle down or file the frame. in my opinion please dont file the frame, it'll just piss you off and in the future youll regret it when getting a new wheel (upgrading etc), and plus you wanna damage your new frame as little as possible.
good luck mate (Y)
