Koxx Coustellier 26"
Alastair
Not sure whether it's available to buy yet
This is the only place I've seen it: http://www.cleanbikes.co.uk/FrameSet%20Pages/Bikes.htm
EDIT: and there: http://www.peppl.com/index.php?page=produc...D%26category%3D - i've no idea what it says but you can make out the geometry e.g. 1095mm wheelbase
Edited by the judge
CADRE: GIACOMO COUSTELLIER FOURCHE: TRY-ALL alu disc JEU DE DIRECTION: Renforcé GUIDON: TRY-ALL Yourself replica POTENCE: TRY-ALL 17° 105mm PEDALIER: TRY-ALL ISIS 175mm BOITIER DE PEDALIER: TRY-ALL ISIS ROUE LIBRE: ACS 18 DENTS CHAINE: TRY-ALL Renforcée FREIN AVANT: MAGURA LOUISE FREIN ARRIERE: MAGURA HS33 PATINS: TRY-ALL JANTES: TRY-ALL XXL percées MOYEU AVANT: TRY-ALL Disc 28 rayons MOYEU ARRIERE: TRY-ALL CNC 32 rayons PNEU have./ARR.: TRY-ALL STIKY 2.0/2.5 PEDALES: TRY-ALL double cage DERAILLEUR: SHIMANO EMPATTEMENT: 1095mm BASES ARRIERES: 385mm POIDS: 10500 g. DISPONIBILITE: VELO COMPLET/ KIT CADRE / CADRE
Frame: Giacomo Coustellier
Forks: Tryall ulu disc
Headset(i think): Reinforced
Bars: Try all yourself replica
Stem: Tryall 17deg 105mm
Cranks: tryall isis 175mm
BB: Tryall isis
freewheel: acs 18t
Chain : tryall reinforced
Front Brake: magura louise
Back Brake: hs33
Pads(maybe....): tryall
Rims: tryall XXL
Hubs: tryall
Tires: tryall sticky, f 2.0 r 2.5
Pedals: tryall double cage
Deraillier: shimano
Geo: 1095wb, 385mm stays
Weight: 10500g
Available: Full bike/Frame kit/frame
Hope that helps (Y)
