Fork Rake - Hifi's?
Phatmike
the rake is measured in degree's from the vertical centre line of the forks
Well, not in trials world where it's measured as Fatmike said.
The Hifi frame is designed for forks with "400mm fork blade with 45mm forward, 10mm bottom head set" (quoting from the echo site). I presume the frame is designed to work with Hifi fork and they are the dimensions of them.
Edited by zordon
