bikerboy16 Posted April 23, 2006 Report Share Posted April 23, 2006 i have just rounded off one of my magura mounts off so i was just woundering if helicoil are any good or is there somethink better that i can do and how many helicoils can you do to a frameplease put up some of your ideas on how to help me cheers Quote Link to comment Share on other sites More sharing options...
Lawnmowerman Posted April 23, 2006 Report Share Posted April 23, 2006 You can either helicoil or timesert your frame, it's easy to do. You can either buy the kit yourself for about £25 so youll need a 4.8mm coil kit and a 5.2mm drill bit. Or you can take it to an engineer to get it done which will probably work out at about the same price. You can helicoil a frame as many times as you want as long as you get the right extractor or are very handy with a drill as you can only tap the coil threads in once Quote Link to comment Share on other sites More sharing options...
Jsy Ben Posted April 23, 2006 Report Share Posted April 23, 2006 helicoil, can someone please give me more of an insight into this "process"...i gather its to replace threads that have been stripped, but what actually happens ? like how come the hole/thread can remain the same size surely you would have to make the new thread bigger ? like dig into the frame more ? baffled Quote Link to comment Share on other sites More sharing options...
Deonn h Posted April 23, 2006 Report Share Posted April 23, 2006 helicoil, can someone please give me more of an insight into this "process"...i gather its to replace threads that have been stripped, but what actually happens ? like how come the hole/thread can remain the same size surely you would have to make the new thread bigger ? like dig into the frame more ? baffled Basically what they do is they tap the stripped thread to the size above e.g. if the thread is m4 then they tap it to m5.Then they screw a steel insert in wich makes it back to m4. .I had my thread in my frame helicoiled it didn`t cost a penny!Takes 2 mins aswell! Quote Link to comment Share on other sites More sharing options...
Jsy Ben Posted April 23, 2006 Report Share Posted April 23, 2006 Basically what they do is they tap the stripped thread to the size above e.g. if the thread is m4 then they tap it to m5.Then they screw a steel insert in wich makes it back to m4. .I had my thread in my frame helicoiled it didn`t cost a penny!Takes 2 mins aswell!ah cheers Quote Link to comment Share on other sites More sharing options...
thread repair Posted March 6, 2007 Report Share Posted March 6, 2007 Basically what they do is they tap the stripped thread to the size above e.g. if the thread is m4 then they tap it to m5.Then they screw a steel insert in wich makes it back to m4. .I had my thread in my frame helicoiled it didn`t cost a penny!Takes 2 mins aswell!The M4 stripped thread is drilled out to 4.2MM (tolerance 4.152-4.292mm) and then tapped with the correct wire insert tap, then the insert is wound in making sure it is installed with 1/2 a thread pitch either end if it is too long cut the oppersite end from the installation tang and make sure there are no burrs. When positioned correctly break the installation tang off either with tang break tool or long nose pliers.Do not use thread lock. The thread is ready to accept the m4 bolt etc. look at wti fasteners ltd website. Quote Link to comment Share on other sites More sharing options...
