Vee Brake Pads
trialsguru
When i ran a front v i ran heatsink white pads on a smooth rim, they were very sharp and quite loud for on a smooth rim and had loads of modulation with loads of lock, i don't really know if heatsink does them anymore though you'll have to see if he's got any.
He does the reds which are apparently identical in performance to the whites.
I've got a load of reds and they kinda act a bit differently depending on loads of stuff. On my stock (with a well dead grind) they have loads of bite and plenty of smooth modulation and quite a 'hard' feel, but on my mod (smooth rim) they're a bit squishier with more lock and less modulation. Both bikes are running Avid SD7s at the mo, so it's definitely a pad/rim thing.
Another thing to note about these pads is that they work best under two different conditions:
1. Slightly damp (but not wet, e.g. one of those days where it rained the night before, everywhere's wet but it ain't raining) - incredible lock, but you lose some modulation
2. Once they've been warmed up (20 mins or so of riding, or a hot day) they get really loud and lock like a mofo. You get the 'demented goose' noise this way.
They suck in proper wet rainy conditions though. And I do mean suck. Thankfully I don't ride in t' rain :) They're easily the best dry-weather V pads I've ever used (but my experience is a bit limited with the more 'recent' V pads, so make of that what you will).
Coust pads are surprisingly grippy on a smooth rim or a very worn grind.. I'd not trust them in the wet though.
The coustellier brothers beg to differ ;)
Cousts are on a medium freshly ground rim are damn good, and brake acceptably in the wet. :)
QUOTE(deanie-b @ May 28 2006, 08:29 AM)
I said on a smooth rim.
They work equally well in the wet as in the dry if your rim is ground. Mine do.
The best vee pads I've ever used for the front are the BBB Triple stop. They're ACE!
IPB ImageIPB Image
http://www.cyclesense.co.uk/products.php?plid=m14b0s104p1430
they look alright, may give them a try next.
koolstop salmon compound are brillient.
