Help With Tensioner Bolts.
zoo
Hi guys
Basically i went to check my rear brake,and saw that the bolt that the snail cams press against to create tension had bent,but upon taking the wheel off i discovered that the bolt has snapped off 3 quarters of the way in.Do any of you have any ideas on how to get it out? Because i do not think i can fit a power drill in the rear end of my bike.....Much appreciation i show !!!!!
zoo baby!
To get the bolt out: use a small flat headed screw driver to turn the bolt or borrow one of those nifty mini drills that bend at a right angle. (Y)
also remember not to wreak the thread! :)
New bolt: i would recomment going to your local bike shop or even your local bolt supplier and seeing if they have one which will fit. :P
Hi guys
zoo baby!
You know you're validated right :blink:
As for the bolt can you not just leave the broken bit in there and run a slightly shorter bolt? Or is it too much still in there?
Oh i know i am validated...but i post here so that everybody on the forum can try to offer help....There is too much bolt left in to just use a shorter one,i tried it but it just doesn't tighten up,thanks for the replies though guys...gonna see what i can do tomorow.
zoo baby!
