221 Pr Or A Echo Light ?
onza t-jammy
The only difference between th two, is the BB rise.
Echo being 15mm higher than the PR.
At a guess, i'd say the PR would be nicer, as the higher BB on the Echo, will make it feel even shorter? :ermm:
But I like long mods. :turned:
Also, the Monty has the rear disc option, whereas the Echo, with very similar geometry, doesn't.
And the Monty's cheaper. ;)
Edited by Dan6061
