Need Help !
trialsviny
Comic Sans eh? heh
Looks like everyone is yet again to lazy to help but would rather argue with one another.
I wouldn't suggest changin any parts on you t-bird because it probably isn't worth it unless it is broke. That way you can save the money for your Zip. But if you need to buy a new freewheel or whatever then you could change it over at a later date to your Zip.
I doubt you need another bb unless its snapped. But at your stage i doubt it.
As for the freewheel. A ACS claws would be fine.
And cranks a pair of Echo cold forged ones. The £50 ones are good enough.
But if you do decide you should really need these parts then buy a half decent set-up which you use for your Zip as well.
So ACS claws freewheel, Echo cranks and a FSA DH bb should be cool. Also try and get a ISIS taper.
Follow...? hope so.
Edited by eskimo
Please explain how that is possible. :blink:
Dan.............
The outside teeth on cheaper freewheels such as diamondback/dicta freewheels can snap at the join, In my case causing me lots of pain and bits of freewheel all over the place :)
Anyway if i was you id get the zip frame then update your parts around it as the zona is a good strong frame :)
mike W :)
Edited by t-comp-mike
