Wheel Building Issue
planet x alan
Are you sure it's not 3x? This might be a stupid question (and a bit patronising!) but the first cross is very near to the hub flange and it's easy to miss. If you put in half the spokes (The trailing spokes) then it's simply a case of putting the leading spokes in over-over-under the ones that are there already. You can't really go wrong?
EDIT: That's a rubbish guide, it's not nearly detailed enough. There's a much better one HERE or HERE.
Tomm's right - you can't really "accidentally" 2X a 3X wheel unless you really balls up, simply because you're counting the number of spokes you've gotta go over/holes around the rim to go, so it kinda takes care of itself?
If you scoot into the FAQ, I did a wheel-building guide in there that has a picture which describes all the crosses and stuff in detail, which may help.
EDIT: You may wanna doublecheck with whoever you got the spokes from that they gave you the right spokes for 3X and not for 2X, by the way.
