Can I Fit The Freewheel Of A Wheel Onto My Cranks ?
Adam-Griffin
of course you can put it on. there is no difference, they go the same way. think about it. would be completely retarded otherwise.
(Y)
Should go on fine, and yeah, just unscrew it anticlockwise with the tool, or a hammer and pokey thing if you dont have it. Just check that you're gunna end up with the right number off teeth for the front.
oh yeh you can thinking about it as people run white industry freewheels on the back
Edited by Deonn h
also what can i use to take a freewheel off ??
your nipples... you need a tool idealy (i think theres one on tarty) hence why most people say take it to a bikeshop. otherwise a chissel/screwdriver(flatheaded) + hammer, put the flat of the chisel/screwdriver on one of th "notches" on the freewheel+hit it alot (Y) but taking it to a bikeshops alot easier etc.
