Front Wheel To Back Wheel Also Know As Wheel Swap
1 ride at the object slowly
2 put your front wheel on top of it
3 when your front wheel is on top of it pull your front brake
4 lean forwards untill you think your going to go over the bars.
5 release the front brake this will make your back wheel drop
6 pull up on your bars when the back wheel hits the object
7 put your back brake on.
8 hop about a bit
9 ride off smiling
10 KEEP PRACTISING
8 hop about a bit
9 ride off smiling
10 KEEP PRACTISING
dont think thats what hes after. although in fairness he could mean about 3 different things:
rolling up something
pigeon
gap to front wheel to switch to back
gap to front wheel to stoppie
:S
The above tips are all heading in the right direction I think but the best way to learn this (in my opinion) is to firstly get the idea of doing it from a rolling start before trying to do it from stationary. By using a rolling start you can then carry your momentum into and though the manoeuvre making it a bit easier and it will help you to learn the kind of shape that you have to make with your body and bike. The key is to keep moving when you do this and not to put your front wheel down, completely come to a halt and then try to do it. If you can do it all in one fluid motion it will be mcuh easier. When you have the hang of that then you will have learnt most of the technique but from stationary the action has to be exagerated!
Hope its of some help to you Alex
i would recomend practicing them on the floor first.
going with the technique mentioned a few posts above
then when you have it on the flat move it onto walls and gaps etc etc
yah i can do them on the floor ond on a wall not verey well
8 hop about a bit
9 ride off smiling
10 KEEP PRACTISING
ok i try it tmro
yes i hade a little go out side my house I will update tomorrow when I get a proper chance to try it properly thanks :cheers:
