Scott Norman Posted May 27, 2007 Report Share Posted May 27, 2007 hi geting my new bike and i was wondering if any 1 could grind the rims for me and how much for???? Quote Link to comment Share on other sites More sharing options...
Muel Posted May 27, 2007 Report Share Posted May 27, 2007 (edited) Just do them yourself mate. Get an angle grinder, turn it on and move the disc around the rim with it at 90 degrees to the rim. The faster you move it down the rim the harsher the grind. Also try and get a diamond tipped disc, they give a better grind. Also make sure its a stone/metal cutting disc. Edited May 27, 2007 by KuelMuel Quote Link to comment Share on other sites More sharing options...
Scott Norman Posted May 27, 2007 Author Report Share Posted May 27, 2007 Just do them yourself mate. Get an angle grinder, turn it on and move the disc around the rim with it at 90 degrees to the rim. The faster you move it down the rim the harsher the grind. Also try and get a diamond tipped disc, they give a better grind. Also make sure its a stone/metal cutting disc.Just do them yourself mate. Get an angle grinder, turn it on and move the disc around the rim with it at 90 degrees to the rim. The faster you move it down the rim the harsher the grind. Also try and get a diamond tipped disc, they give a better grind. Also make sure its a stone/metal cutting disc.yes but knowing me i put a masive cut through the rim Quote Link to comment Share on other sites More sharing options...
Grant H Posted May 27, 2007 Report Share Posted May 27, 2007 i'll do it for a tenner Quote Link to comment Share on other sites More sharing options...
Dave Anscombe Posted May 27, 2007 Report Share Posted May 27, 2007 im shure if you ask one of the local lads they will do it for you.......maybe try dan walker he might do them for youthink he lives in ur area Quote Link to comment Share on other sites More sharing options...
Scott Norman Posted May 28, 2007 Author Report Share Posted May 28, 2007 im shure if you ask one of the local lads they will do it for you.......maybe try dan walker he might do them for youthink he lives in ur areaok thanks i will ask him Quote Link to comment Share on other sites More sharing options...
