Bleeding Echo Cnc Rim Brakes - Oil Or Water?
Rusty190
Hello!
I know many prefer bleeding with water instead of oil. I´ve tried bleeding my Echo brakes with water, but Im not satisfied. (The bathtub method) My second attempt to bleed the rearbrake seemed to be very good, but some days later, the brake didn´t respond very well... =( I took a check at Tartys, and found this text regarding Echo CNC Rim Brakes:
"Please note that using water to bleed the brake will invalidate the warranty." -Will the Echos get broken? Corrode?
Maybe water works best with Maguras?
Any help is much appreciated!
Edited by Rusty190
  • 4 weeks later...
Unlike a magura which has plastic seals the echo had metal ones and will corode and leak and completley kill the brake, so yeh oild for a deng brake m8.
Metal seals?
Also these brakes are made out of aluminium which doesn't corrode. The only bit that does, secures the piston in the caliper. Uncovering it is a nifty way of checking if the brake has been run on water since that little bit will rust.
