Rear Disc Or The Echo Rim Brake ?
JoeEden
:o
Well, you're one of those few riders who gets on with them :) But for the majority, these brakes are too weak. I love the idea of dual disc, just not on a stock - tried it and the brake was way too weak for my liking. On the other hand I had a dual disc mod and if i was ever to go back to mod (which i am) i'd get a dual disc setup (which i will).
would you trust a bb7 on the rear?? i for sure wouldnt!
In what way? Power wise yes although i heard some people say they snap.
I would get an echo rim brake because a disc brake still flexes a little bit so a rim brake will hold more
with a rim brake you get frame flex so either way you get some kind of flex.
and the flex with mono trials is tiny, it barely moves.
Wtf, are you serious?
Lets weight it up, a standard magura flexes more than most discs as it is?
Echo's have more power for whatever reason it is, I cant remember now. So it's just going to make it flex more.
A 203mm avid bb7 would do the job I'd of thought, just like a hs33 will do too.
hi there what would you the echo rim brake on the rear or a disc something like hope 07 or hope mono trial ? :huh:
Hi there i would go with a rear disc , a avid juicy 5 they are a lovely brake to run on the rear as thy have a solid pull on the leaver (no sponge like hope ).
Plus these echo rim brakes have been getting bad reviews with the piston body's leaking at the seams! (complete leavers are mint though when ran on a maggy).
keep it easy
Jamie
