Ly Mite
Monty99
is it just the rear hub v!z or the rim as well?? if its a v!z rim you have done the worst thing ever. they dent if you back wheel a cerb.
Actually i bought that wheel (viz-rim only) in 08/05. So it lasts nearly 2 years (about 5 grinds) without any dents. The spoke tension is perfect since i got the wheel. Maybe the new viz-rims are crap, but there is no reason why i should say something about mine.
  • 1 month later...
  • 1 year later...
those were something like 06.5...bought it in may 06 when it was released.
new rotor is an Alligator 180mm TiN alloyed 111g (lighter than a Magura 160mm)
edit: old Echo Team had a closed gusset on the down tube/steerer join
Edited by Monty99
