Echo Pure
Andeee
Well heres my new frame i got her built up on monday.
Big thanks to tarty as im very happy with the pure now:).
Spec:Echo pure frame 1075, onza lite guy forks, red chris king threadless headset, hope cnc stem in red, red try-all bars, front avid bb7 with xtr lever, rear hs33 with zoo! pads, front red try-all rim on a hope pro2 hub, rear red try-all rim on a pro2 trial 6 speed hub, onza cranks, red wellgo pedals, 8 speed sram shifter, 9 speed shimano tiagra mech, 8 speed sram chain, tarty raffle grips, front maxxis advantage tyre 2.10 and a rear maxxis hansventure 2.40.
Cheers andrew
Edited by Andrew Quibell
Hey,
I built up my new pure just over a week ago, the back end is longer than the old one so am still getting used to the slow acceleration. What do you think??
OLD one:
New one:
Regards
Agreed mate ive noticed with my pure i can get more control on the backwheel for turns etc and the old pure it was too stiff if you get what i mean.
Andrew
you need to get some new cranks ont there lolcan sort you out with some burns cheap if you want them catch me on msn if interestedlooking good though
Yeah thanks steve that is my next thing in mind all i need now to finish it to a good spec is new cranks i.e burns, zoo stem, old zoo bars and a booster. Edited by Andrew Quibell
whats it like without a booster ??? does it flex loads ? the bike looks ok but cut the steerer down cos it spoils it abit.
Its pretty alright actually as im running tensile off set mounts and my brake is set up orite but flexes a little bit every now and then.
Andrew
  • 2 weeks later...
