Brake Pads Non Grind Rims
Paul B
Hi)
Looking at getting pads for a non ground rim options out there Anyone? Pads + Tar or ? Cost, modulation, wear , Squeak or not? where purchased Let me know . I don't care about noise just as long as they Grab Hard)
Thanks for all comments Paul
Rock greens. For smooth rims.
Matt Rushton
bad idea, unless you use tar. these pads are too soft and don't actually perform that well on smooth rim..
plazmatic crm's work a treat on echo 07 rims (as long as the anodizing hasn't been taken off)
Rock greens are not too soft for a smooth rim, have you ever ran them on smooth?, becuase mine were mint and lasted ages
Edited by afroman
Just grind your rim. You will get so much better performance when you have a grind. Then get some rock blues or plaz pads.
Or better Koxx Bloxx brown, in my opinion they are the best for grinded rim :rolleyes:
Edited by Gh0s7
Are the V!Z pads (orange) good on a light grind for the rear compaird to the ZOO!'s? or.. .. wich koxx bloxx are best for wet weather?
koxx blues for wet work ok in dry aswel , but dont get them any ware near a harsh or medium grind otherwise they will last you like no time ,lol
ok wifth tar on a smooth rim
leon
