One Shortcut, Two Folders
Smo™
Hey guys,
I have two folders on my computer which contain files of the same type. Each of these folders is on a different HDD and therefore I have to access each one seperately with their own shortcuts. My question is this - can I create some kind of shortcut whereby when I click it, I get a window opened which contains all the files from both of those folders?
Cheers.
open notepad
copy& paste this into it
Set objShell = WScript.CreateObject("WScript.Shell")
objShell.Run "explorer.exe c:\porn" , 1
objShell.Run "explorer.exe " & objShell.SpecialFolders.Item("MyDocuments"), 1
objShell.Run "explorer.exe " & objShell.SpecialFolders.Item("Desktop"), 1
objShell.Run "explorer.exe " & objShell.SpecialFolders.Item("MyDocuments") & "\porn", 1
save the file as mylovelyshortcutthatopenslotsoffolders.vbs or something
When you double click on it, 4 explorer windows will magically open - one on your c:\porn folder, one on your documents, one on your desktop and one on your other porn folder.
delete and edit things as required - if you balls it up don't come running to me :P
