Avid Arch Rival Supreme
El Cristoff
Hay all,
Basically, i hate my brake at the moment, and i want to go Vee.
I have been offered a Avid arch rival ultimate or supreme, just wanting to know a bit about them (I have searched)
Any good for trials?
Its the ones with sealed bearings like the ultimate.
Cheers,
Chris
Edited by El Cristoff
The old Avid Arch rivals used to rattle alot where the arch joins the brake. I know they may have sealed bearings but at the end of the day you want the stiffest arms possible. For how cheap they are on CRC an SD7 is pretty good (£16.99). Or the SL's are lighter by 2 grams than an ultimate at £30 and then there is also the SD Ti's that only cost £24.99. Personally an SD7 will do you fine.
PS, I run an ultimate on the rear (lever and arms) with a linear slic cable and it is spot on. Much nicer than a magura with plenty of hold with plaz crv pads. The best thing is the spring tension can be set real low and cuts down on arm pump loads. Oh and i run it on an 06 Ashton without a booster and find there is minimal flex.
arch rivals and ultimates are two different types of vee
the arch rival has an integrated booster, and is a toss brake, don't bother
the ultimate has conventional style arms, but cnc'd, and with sealed cartridge bearings-superb brakes, i've had several now :)
EDIT i stand corrected after some research, there is also a arch rival with sealed bearings...but you still want a regular ultimate either way!
Edited by pauloliver
