Tech Question
chris222pher
hi guys
i know this sounds stupid and i have done it loads of times before just not on this set up, how do i take my echo urban forks out of a green echo cnc headset, unless the steerer is bent surely they should drop out when i take the stem and star nut out unless there is some kind of locking device i dont know about.
any help appreciated
chris
Sometimes they need some encouragement, get a rubber mallet and gently tap whack the top of the steerer.
There's often a wedge shaped bit at the top of the headset, as you tighten everything up, this gets pushed into the forks/headset, locking itself in a bit tight.
Few knocks with a mallet should pop it all apart :)
because of the way the wedge tightens everything up, knocking the top of the steerer will push it in further theoretically.
It might be best to try giving it just a couple of tiny taps, then try and push the forks back up to loosen the wedge, then pull the wedge out and the forks are free of the headset :)
