Front Disc
Matthew_Gibson
My BB7 2007 is shot. Cracked, and generally dead. =[ I will be needing a new one. Just wondered what to go for. Either another BB7 or move on. and get a Hope hydro disc? I'm unsure about hydros. as I've had bad experiences with them in the past. They never held fluid and never worked. (but they were both second hand)
My options are: BB7 2008
BB72007 Rear (just put on the front, Would it work???)
Hope Trials disc.
Something from the Magura range.
I like having bite and hold, and something thats going to slow me down on hills!! . But my avid has lacked that since I put a new disc on. WHat are the advantages of hydro discs over cable? I really dont want to spend a fortune.
Thanks!!!
I think you should possibly condiser something from the magura range , every time i have used a magura disk brake they have had phenominal stopping power and great reliabilty . If your not up for spending about £200 on a marta sl then buy a magura louis .
On the mechanical side consider a hayes mx2 there amazing brakes very similar to the bb5 the only differance is its better and not cast .
hope my input helped .
Wouldn't trust them EVER! Went on a freeride bike, and that had hayes on! they didn't work AT ALL!!!
I had a Hayes HFX9 on the front of my KO, was absolutely shite, no bite atall, it never slipped but , my tektro was better.
Havnt had chance to use my BB7 on a trials bike but it seemed Pretty amazing on my other bike, it might be an idea to consider other hopes rather than just the Mono trials, maybe some downhill/xc/freeride brakes ? Avid Juicys?
Hope C2's and M4's will give you more than enough stopping power, maybe abit over kill though...
Edited by Adam-Griffin
have any of you actualy researched what hayes mx2 is ? have any of you used one ?
because i have had 2 and both of them were better than a avid bb7 and its a mechanical brake that works on the same principal as a bb5 with one piston stationary and the other moving .
Got it working mint. Set it up proper good. Needed spacers to stopit catching. Not on the forks though. were the adaptor fits. (black arrow) Also put a metal ferule thing on, rather than plastic
I think its going to split to the right of the black line. If / When it does. I'll get an 08
