New Cranks/ New Freewheel Problem.
rudirudirudirudirudi
ok, just got my echo forged cranks and monty freewheel through post. when i try threading the freewheel on it goes like one turn round then gets reaaaal stiff. like its crossthreaded or sumin..... looks perfectly straight. took it back off and theres little like frays of metal. im stripping something but how???? is it just stiff cos its new??????. what am i striping?
No, I bought some brand new echo cranks and an echo frewheel and it went on really smoothly so i doubt it's that try using copper grease or something as it will make it easier if you ever need to take it back off, i just screwed mione straight on and i need to get the FW of to put a bash ring on now and it's stiff as a camel :(
well it defo wasnt cross threaded. i think what the problem was, was that on the freewheel threads there was a bur. because it was on one side of each thread on the crank that was being stripped. its on fine now. i just did what dave said. it didnt take much off i dont think. :unsure:
cheers for your help guys.
will u still be riding soton?
c you tomz random guy of the train :P
..rob..
Both new parts?
If not, did you clean up the threads before you put it all on?
Try just scraping around the threads with a cloth soaked in WD40 or something, then give it a dab of grease and try again.
Sometimes new threads can be stiff to go on, especially on cranks as they're still painted. It'll go on easier where you've already threaded it on. I'm sure after a Good clean, and a flush fit it'll be fine, but if you see metal again.. STOP!
