Drive Chain!
Matthew_Gibson
Just put my new echo cranks on my bike, haven't sorted the chain tension out, but it look as it its going to rub on the frame. I'm currently running 18:18 which I'm going to change. But I'm not sure if its going to work. Has anyone else had the problem? The rear cog will be 15 tooth and this will make the ration 1:2 with is same as 22/18.
I'll get pics up later!!
do you mean the chain is going to rub on the chainstays? i have a fairly small gap between my chainstays and chain on my simtra,and im running 18:15 .just wondering,what frame are you using ?
steve
i dont really understand whats supposed to be rubbing...i think he rides an a1
Well don't post in the thread then, it just seems like your spamming the crap out of the forum with your replies.
I'm pretty sure it his chain on the chainstays like mentioned. So what hub isit? That will make the most difference. If your on a Pro2 or non single speed hub then you could play about with the chainline. But that will mean using another bottom bracket or having a poor chain alignment. A 16/16 gear would work as well shouldn't it? Unless you've already screwed that sprocket on...
