Rb Booster
lewis.jackson
So are you saying that if its the frame iv got a crack in it after one small ride?
no
Just means that the booster is keeping everything at the top stiff and the frame must not be to stiff so is flexing. Theres not alot you can do about it
and the brake is bled ok?
Yer thats ok.
With a flexy frame and a flexy booster, there will always be some flex. 5mm sounds way OTT - any chance of a more exact measurement? I would guess approx 2mm tops, which is fine.
Its more then 2mm. Ill try and put a hs33 booster behind the rb to see what happens.
Lewis when i had that rb booster on my echo it didnt sponge att all, and when i didnt have it on the frame was flexy. so the booster was stiff
On my T-comp (07) the brake used to flex madly, I put a Tensile on it and that eliminated the flex.
I've now switched to an RB booster and I can definatly feel it flex again, although its not enough to annoy me :D
