Brakes Keep Slipping
mista-neos
This happens when ever i hop on walls and rails its realy anoying because i just had them bled. Any help please
x0x0-neos
what pads are you using??
i had this problem with magura reds. i did a grind on my rim and bought some koxx bloxx browns, must say my brakes never felt so good (Y)
hope this helps
  • 3 weeks later...
Christmas List
1. Get a grind
2. Get New pads ( Koxx Bloxx , Coust ) any after market pads are better than the original magura reds/blacks
3. Get a brake booster if you want even more power as the back of your frame will flex quite alot ( your choice on this one)
4. Make Sure Pads are set up near enough perfectly
Then try Your Brake , Should Never slip after that even on the big gaps , etc :D
Nathan
