11t Fixed Cogs And Below?
eskimo
Screw on? It's not possible with standard hubs as the thread size is too large for 11T... would work with M30x1 I reckon but never seen one available :(
I know the normal hubs now are 12t only but i've seen smaller threads before. I just wondered, it would be cool though.
I think it's the Alfine groupset from Shimano that has a 9 tooth sprocket at the back.. It's designed for folding bikes, so trials is pretty much guaranteed to snap it. There are some BMX drivetrains with 9T sprockets too AFAIK, again I'm not too sure they're strong enough for trials, but they might be. It's always better to go with the biggest sprockets you can as this takes a lot of stress off your chain (More teeth means load is transferred by more rollers, bigger sprockets means less tension for a given crank force)... The only reason to go with small sprockets is to save weight, and saving weight at the expense of a chain that's more likely to fail probably isn't all that wise...
