Testing Dengura Pistons
BenLeacock™
Bleed it with water and squeeze,
see if anything happens.
It is bled with water. :P
Checked all the fittings are tight? Incuding bleed bolts?
What lever is it? You can rebuild the maggy levers, so you will be able to check if the seal has been damaged.
Pressure test it
stick the two pistons in a vice so that the pads are against each other as if your setting them up on your wheel but just without the wheel and make sure the pads are touching. Then just pull the lever quite hard and see if there is any leeks.
Cheers jammy
Edited by JaMmY
