Spokes
Tro dig inte
the best spokes i would say are the Mutiny spokes on tartybikes (Y)
Even the trialtech ones look good to and in white (Y)
Mutiny spokes and Trialtech spokes are the same. Among the hundred of other bmx spoke makes. Get some Prolite double butted spokes if they can supply you the correct size. I know they come in alot of sizes not mentioned but no 174/5/6 etc
As for stock, Sapim and DT race/ champion or whatever.
Also silver spokes are stronger.
I don't think that it really matters that much, as long as you set the tension up right and your not a weight weenie then one spoke is just as good as the next. If you really want to change your spokes though, go for something colourful just because they always look great.
If your spokes keep snapping then you're probably not stress relieving your wheels properly. Look up stress relieving on pretty much any bike forum or Sheldonbrown.com and you'll get decent instructions. A wheel is a pre stressed structure. This means there's stress in the structure before any working loads come onto it. To carry a load the spoke pointed towards the ground loses tension while the rest of the spokes gain tension very slightly (Tension lost in spoke pointed towards the ground divided by the number of remaining spokes). Doing up a wheel slack will not make it more durable for this reason. Using double butted spokes will make the wheel more durable as they stretch more for a given tension, so at high loads the rim will have to deform more before the spoke becomes slack.
So - to summarise, slack wheels are not more durable, double butted spokes are and stress relieving wheels makes them far more durable than any other change you can make.
