Please Read!
ok hello peeps!!! i know this has already been posted but bear with me. :sleeping:
i want to know the correct gearing to ride for my 26incher!! (oooeeerr missus!!!)
will have to keep my standard 22 granny ring though I LOOKED AT THAT GEAR LINK AND DIDNT UNDERSTAND ANY OF IT IM THICK AS PIG PLOP!!!! any help would be great help cheers :rolleyes::rolleyes:
This has been said in pretty much every other discussion on the same topic and in fact a few of the posts on this one. DO NOT USE A GEAR BECAUSE SOMEONE ELSE TELLS YOU IT IS RIGHT! I am not having a go, I jsut feel that it is important that you try a couple of different gears, maybe one per ride until you find one you get comfertable with. Probably the most common is 22:18 however everyone prefers using slightly different gearing.
