My Stock 26" Bt Raven 8.0 Vertical
EranFuld
I've finally completed my My Stock 26" 135mm BT Raven 8.0 Vertical project:
I'll be more than happy to attach pictures once validated :-)
Frame: Stock 26" 135mm BT Raven 8.0 Vertical 1072mm, 379mm, 20mm
Fork: Cannondale Fatty R
Handlebars: Adamant Riser Bar 740mm
Stem: Kore 110mm 6 deg
Rear Rim: Alex DX 32
Front Rim: Rhyno Lite
Rear Tire: Maxxis Mobster 2.5
Front Tire: Maxxis Minion 2.35
Rear Brake: Magura HS-33
Front Brake: Avid BB7 185mm
Cranks: Truvativ Holzfeller ISIS
BB: Truvativ Gigapipe DH
Bashguard: Pilo 22T
Rear Hub: Surly
Rear Freewheel: WhiteIndustries 20T
Front Chainring: MiddleBurn 22T
Front Hub: Formula
Booster: Echo 4 Bolts
Pedals: Wellgo A52 Platform
Use Photobucket well make an account and upload the photos to it and then after that underneath the picture on photobucket copy the URL
then when you reply/edit on here there will be some kind of green icons on of them says insert image then paster the url into it.
Edited by Czartrials
Thanks a lot, I had no idea it is possible.
By the way, any rear wheel hops tips you could share?
I am currently trying all 3 options:
1. From an Endo to rear wheel.
2. using a high object (about 75cm high).
3. using a pedal kick.
#1 works fine expect it requires too much energy.
Which is the fastest way in your opnion?
Again thanks for the picture tips,
-Eran
P.s
Sorry for the delayed reply ;-)
Pedalstroke to get it up on the back wheel :)
Thanks man.
I kind of figured it's the best way, I mean if I'm already a touch away from performing more than 2-3 hops on the backwheel by a pedal stroke.
Any other method would be like going backwards as far as progression counts :-)
Thanks again,
-Eran
