Diffrences Between 20inch And 26inch Trials Bikes
Hodgey1
About 6 inches?
You only said that because the other knob said that \/
One has bigger wheels than the other?
Either way, absolute twats, he was looking for help...
Is that too hard to understand for you neanderthals?
Defference between bikes <that's a great site, mate.
Look over it and things will become clear
Edited by BenJohn-Hynes
Modified (20" wheels)
  • Pros:
    • Superb standover clearance
    • Easily manueverable in most every circumstance, especially anything rear wheel
    • Less expensive
      • Less parts to break
      • Nearly impossible to bend the rim of a well-built 19" rear mod wheel running enough tire pressure
      • Learn to sidehop up to both sides without worrying about a rear derailleur
    Cons:
    • Some people may think it's a BMX bike
    • A pain to ride more than a mile or two on
    • May be harder to find parts for it
    • Harder to roll down things
    • Easier to go over the handlebars (but less scary when you do)
    • Doing wedge or wheelbase moves is less comfortable
pixel.gifStock (26" wheels)
  • Pros:
    • More stable
    • Bigger wheels = roll everything easier
    • Easier to do wedge or wheelbase moves
    • Easier to pedal-kick on odd surfaces because of the larger diameter wheel
    • You can ride to your riding spot easily (if you have a seat and working gears)
    • Looks more like a mountain bike
    • People won't ask you to "grind" stuff or think you do BMX vert or street
    Cons:
    • Bigger bike = less standover clearance = pain if you fall on the bike
    • Easy to hit knees on top-tube of most bikes
    • Less room to work with for bending down before sidehopping, bunnyhopping, etc. or when absorbing landings
    • More expensive because of greater frequency of breakage and more parts to break
      • Rear derailleurs - easy to smash into things (though most bikes have replaceable derailleur hangers that will bend before the derailleur is broken)
      • Wheels - 26" size = easier to get out of true or taco (20" wheels are extremely hard to ruin when built and used properly)
      • Chain can slip down or up a gear while you ride if your chain is too loose, or you smack your derailleur in section and break it
    • Heavier
Some people say that 20" bikes are easier to learn moves on and better to start off on? <-( If that is true I don't know) One advantage to a 20" other than weight would be that you have more room to move around on objects because you have smaller wheels. I personally started off on a stock and still ride one and love it. Hope that helps a bit.
-Sam
I think it's a preference thing, so see if you can ride both and see what you prefer. One may ultimately feel more 'right' for you.
Although I like 20's and 26's so you may end up wanting both!
I do use the my 26'' jump/street/everything else bike more than my Monty though (when it's not in pieces in my garage...).
Edited by Paul_C
