I Cant Forward Hop =[ Help Please!
jewish james
First of all i would try and learn to get your balence in one one spot by just rocking forward and back slightly hold both brakes, then when comfortable put a bit more pressure on the back and lean all your weight over the back and give a lil kick with the pedels just to pop you up a bit easyier, then lower your front end and same agen lil kick and pull up with the bars and your be hopping no time
Well thats how i leanrt so maybe for someone else
Will x
Switching your leading foot may help. I've noticed I can pedal kick far easier with my left than my right, makes it a bit awkward having to switch for just one move, but it could help you to get it up so you can find your balance point, making it easier to switch to your good foot as you progress.
