Echo Or Try All Rims
1woz0
you all say try-all are better just cause there lighter, but none of you have said about there strength!
I'm useing a echo on the rear and i have hit it quite a bit and it hasent dented and my mate has got a echo too and he hasent dented his so IMO get the echo
depends on if you want a really strong street bashers wheel or a natty wheel thats almost as strong :P
if anyone says that a echo rim is much heavier dont listen to them theres only about 8 grams in diference (weighed by myself)
but im running a try-all and havent had one problemo yet *touches wood*
People always say "echo's are stronger" but to be honest i have never had a problem with try-all rims, and i am the heaviest rider on this forum! The other thing that alot of riders will go on about is how an echo rim will hold a grind longer, it is true to an extent, but with the right pad combo etc a brake will work on a try-all for ages and still be imense, anybody who has ridden my bike will agree that my brake is stupidly good!
Yes the try-all is lighter which is a reason i run them.
You can not realy go wrong with either realy, to be honest.
Also, is this for 20 or 26inch?
Adam
His profile says mod Adam. :P
If you want a lightweight rim that holds a grind pretty well, have a look at the Monty TIs, I used to have one, and the grind lasted for about a month with Rock Blues, and I rode in the rain a couple of times.
I've had Try-Alls with grinds in the past, and they were OK, but no-where near as good as my Monty was.
Adam
Lies! Your smoo-ooth, with a capital smoo.
:P
