Old School Magura Hs33
Gogz-
The way in that how to doesn't seem the neatest way to do it to me to be honest, if you replace the sheared bolt with another of the same thread, and cut a slot in the head so it can be used exactly as the original you still have the lovely red adjuster, and is probs more solid than the original. I'm guessing plenty people do it this way and i'm being dense? just thought i'd mention it, but feel free to shoot me down.
do you keep every bit of the TPA (Am I only replacing the sheared bolt).
It looks as if there is 2 bits of bolt sheared off both so small it looks almost impossible to remove it.
Keep the piece on the left, and try to get the remains on the bolt out.
Find a short M5 bolt (Magura bolt size?) and then cut a slot in the head, so the 'plate' part of the Magura lever fits into it.
With that done, you can now screw the bolt back into the square nut thing, and build the lever up, without anyone knowing it's bodged! :shifty:
EDIT: Looks like there's enough bolt sticking out to grip it with some mole grips/pliers, and just twist it out.
Edited by Dan6061
That DIY manual is missing one important thing, that square-ish part which the TPA adjuster sits on needs to be permanently glued into the lever.
Which bit are you taking about because I haven't had to glue any thing in and it seems to work OK .
Yeah that's exactly what i meant but i described it less well, and for this method nothing needs to be glued anywhere as it is still working as intended, just with the bolt replaced.
Edited by moonboots
Later on the bushing that holds the red TPA cap breaks perpendicular to the threads, so the TPA knob unscrews off the bolt rather than adjusting the bite point. The brake still works, but you have to pull the lever apart to make TPA adjustments, which is a bit annoying...
  • 2 weeks later...
