My New 09 Echo Control
netto
HUUUUGE thanks to Graham at midwestbiketrials.com, Aki at trialspads.com, and Kevin Chen from worldcat. Graham was really patient with my order and shipping. Props
I will post a review on the specialized clutch sx tire after i spend a little more time on it, but after the first ride, i'm convinced that this will be a very good tire.
The Echo SL rear rim is pretty heavy at 780g, but it will only need to last me for the next 3 weeks, until my new worldcat single wall rims (try all hole anyone?) arrive.
not sure how accurate this scale was, but here's the weight of the bike without the front rotor and rotor bolts
the specs :
Frame : Echo Control 2009 short
Fork : Trialtech
Stem : Trialtech 120x17
Bar : Zhi 7075
headset : Echo SL
Front Brake : Magura Louise FR 180mm with Ashima rotor
Rear Brake : Echo SL with Echo tr mount (no plastic spacer), rock pad blue (soon to be phatpad cnc), and Trialtech carbon fiber booster
Front Hub : Worldcat
Front Rim : Neon Pro (497g)
Fr Tire : Continental Speed King 2.1
Rear Hub : Echo SL 135mm with 16t cog
Rear Rim : Echo SL rear spray painted white
R Tire : Specialized Clutch SX 2.3
Bottom Bracket : Neon Titanium
Cranks : Try All 170mm
Freewheel : Rockman 72pt
Bashring : Echo SL
Pedals : Wellgo Mg-1
Thats one gorgeous peice of kit bud.
Not heard of those brake mounts. I take it it works the same way as using two bottom parts of a normal maggi 4 bolt mount?
I believe its like the Tryall ones aswell that have the grooves machined into them to match the ones on the slaves. The brake mounts on the frame have to be pretty square aswell as there is only rotational adjustment.
that's right. so far they work amazing. thanks for the positive comments :)
