Building A Frame On Marinonbikes.com
Nuke Bowel
I have started to build a frame on Marinobikes.com for my girlfriend as I have so many parts I'd prefer to get her a frame in a color she wants at a good price.
First of all, what bb type do I choose?
Secondly, where it says bb rise, I want to put 304mm as that's what I'm copying from the geometry from a Specialized Myka womens specific frame, but it will only allow me to insert two digits, what do I put? :S
Lastly, what do I put for Brake mount spacing?
Cheers Luke
304mm is the BB height, not the rise. The BB rise is the difference up from the wheel axel. The BB height is the Radius of the wheel + the BB rise
That explains it then, cheers!
Could you possibly find me a nice rise height that would suit her?
Cheers
Measure from the centre of the wheel axle to the edge of the rim, there you have your radius.
What sort of rim's going on the back?
How can I if i don't have the bike yet?
I just need a diameter I can knock in there, if someone could come up with one.
This is the geometry I'm nicking clicky
I'll be running mavic cross max disc's as I have some here
Are they 24" or 26" wheels??
If they are 24" wheels, then 304mm is a 0mm rise.
If they are 26" wheels, then 304mm is a 25mm drop
26", thank you very much, so the bb rise is -25mm?
Right,
We have come to the concusion I want a - 25 bb drop, euro bb, but all I need to know now is what brake mount spacing I need?
I am right in saying I want a 135mm vertical 10mm drop outs?
Or am I incorrect.
Many thanks, with these answers sorted i'll be able to order :)
Right,
Or am I incorrect.
ignore me.
Edited by Ladd
Right,
Or am I incorrect.
yerp sounds about right for a standard mtb rear hub setup (Y)
if its vee mount spacing they're normally 80mm?
Edited by Alex Dark
