My Zoo Piranha
laurent
This is my new bike: Zoo piranha.
After using an hydroxx during several month, i'm really surprised...this bike feels better.
Not so light: around 9.7kg.
Quick spec:
Zoo piranha 09 frame
Echo urban fork
Rockman handlebar
Echo stem
Front wheel: try all hub with try all rim and dt revolution spokes
rear wheel: viz hub with try all rim (drilled on the outter and on the inner walls)
Try all cranks
Eno freewheel
Rear hs 33
Front brake: avid bb7
Front tire: continental speed king supersonic (amazing tire!)
Rear tire: rubber queen 2.2
Darn everybody's getting a new Zoo! Pretty nice bike there mate!
You know why everybody will have this bike....
This frame is quite light and the price is very low!
I paid mine less than 200£
But i assume that cheap and light can't last.....i don't think it's a strong frame.
Yeah, strength might be sacrificed, but we'll have to see. Deng is known for making good strong frames so they might be alright.
And if i crack the frame i just have to buy another one.
The price is so low that it's possible to buy 3 zoo piranha for the price of a koxx, ozonys or so...
So even if it will not last it will not be a disappointment.
And for the price the frame is quite nice to ride.
It's lighter because there is hardly and blocks of cnc. I doubt he is using really thin tubing.
I don't think either that the tubing is too thin.
But the tubing is no as oversized as it's on my 07 echo pure frame for example.
Maybe it's wrong, but i juste have the feeling that the frame is not so strong.
Moreover the low weight is also due to the fact that there is no extra "parts" on this frame: not any cable routing, and the "brake bosster" is very very small. That's why this frame needs an extra brake bosster.
What gear ratio are you running? I love these frames but don't know if I can get a good chain length with 383 cs. I run 22-18 or 22-19.
I'm running a 18-15 ratio.
lovely bike there, is there alotof flex in those frames?
The frame seems stiff enough for me.
Maybe less than my previous hydroxx but stiff enough.
