Mbt Bikes
Luke_zoo
Right..
I'm building up my bike and I want a single speed kit, i'm running 22T front and I have no idea what to have on the rear, I want it hard/easy as I'm going to be dirt jumping on it, any ideas?, before i buy on tartybikes.
Help welcome :)
hard easy? which?!
er id say 15t maybe?
For MTB dirt jumping the normal ration is 2:1 so the norm is 32:16, I personally think that is still a bit light and use somewhere between 36:16 and 36:12 depending on the run in. 22t front chainring will be sh*t unless you are riding jumps that have a roll in so require no pedalling in which case gearing doesn't really matter.
I used to run 33 to 11. On a dirt jumper was pretty sweet. Could accelerate easily and get a pretty good top speed. But i agree with what others say 22 is too small for DJ. This is all presuming you don't want to do anything but jumping on it.
if you run a 11 on the back thats going to be the closest your going to get to the standard 32:16 going by the sum: number of teeth on the front sprocket / number of teeth on the rear sprocket x wheel size so 22/11x26=52 you want something in the region of 55 for the best average gearing (32/16x26=55) you can use the same sum for all bikes and gearing just alternate the wheel size.
i run 38 on the front and 16 on the back thats a 61 fairly hard but just right for me on a 26'' wheel :)
hope that helps a bit
ash.
