What Bottom Brackets Are Folk Using These Days?
duncshaw
If its an ISIS I'd go with an Echo (Or Superstar they're the same thing as far as I can tell) or if bearing durability is an issue the SKF ones - just make sure you get the right tool to fit the SKF's. I've been running an Echo BB for over 1.5 years with no problems :).
If its an ISIS I'd go with an Echo (Or Superstar they're the same thing as far as I can tell) or if bearing durability is an issue the SKF ones - just make sure you get the right tool to fit the SKF's. I've been running an Echo BB for over 1.5 years with no problems :) .
if you get the skf, make sure you get your frame faced. the cunting lockrings keep breaking otherwise
my monty had a FAG BB in it for at least 6 years. the dam thing is basically plastic. the only reason why it broke is because i pulled out out to clean the BB area out and tightened the cup to much then rode an event on it thus breaking the too tight cup.
