Back To Vee And Ready For Bristol.
Otacon
Hey guys, was running front Magura, found a crack in my forks about a week - 2 weeks ago, and its now got massive, so back to vee :)
Bikes all ready now for Bristol In september :D
Spec:
Echo Control 06 long
Kot forks
FSA headset
Echo hifi stem
04' Zoo bars
Front hope xc on dx32 with maxxis high roller
Rear Hope pro 2 trials on dx32 with maxxis high roller
Front random vee brake, with plaz crvs and avid sd3 lever
Rear 04 magura, phat pads in cnc
Echo external bb
Echo cnc cranks
zoo bash
plaz cog
kmc 1/8" chain
trialtech grips
The crack:
The bike:
Comments ready :)
Edited by Otacon
Vee Holds a hell of alot more, Just got no noise and not much bite, so ive got MEGA amounts of hold and modulation and no noise....Not to bad.
You all set for Bristol Ben ?
Gonna head over to Brum soon for a catch up ride, Due want your £20 in Bristol ?
bit o tar will sort that out ;)
a grind adds bite??
hardly, your front vee swishs for about 5 mins before it bites, were as mine stops dead and i hardly ever even use tar, and your rear vee swooshs forwards and just holds backwards, and when i put mine on the back it was ace bite and hold, but was noisy so meh.
Measures in axle to axle at - 1150mm :)
wow, just shows how great dengs tolerences are on his frames, pritty sure the longest control made was 1085. unless your forks are bent to f**k
im pritty sure ali's bite is crazy good on his uses a grind, may be try different pads
Edited by basher
doubt dannys gonna grind his front rim anytime soon, think he wants his pads to last abit.
and my vees monster without a grind so i dont need new pads or grind etc, i just dont ride in the rain
Edited by Mat Smith!!
So you have a disk!? lol
Yerr am all sorted, just hope my bike holds up until then haha. Whenever suits you dood(apart from never) :)
Yeah haha:D
He said he wanted bite not hold ;).
I never once said i wanted bite, my brakes perfect how it is.
Lol, i dunno, f**k all wrong with dengs frames, he makes best frames in the world if you ask me but meh. Forks arnt bent and thats what it measures at. :)
In my experience, a grind on the front will refuse to work. I've tried loads of different set ups and grinds, and none of them have worked. :(
Spot on Ben :)
Cheers for comments people. :)
  • 3 weeks later...
