Computer Issue
Ben John-Hynes
Hey everyone.
Since yesterday I've have the blue screen problem twice. No idea what it is, no idea how to cure it or I have no idea what caused it.
My laptop is pretty much brand new(May).
Can anyone help me cure/stop it happening? It's pissing annoying!!!
Cheers for any help.
Edited by Ben John-Hynes
If you haven't already sorted it, post up the error code you're getting on the screen.
Does it occur randomly or when you do something?
Have to eliminated a basic hardware malfunction? Remove the battery and run on AC only, remove the CD drive and all USB hardware and basically run it as minimal as possible.
Bad advice. BSOD is usually caused by a hardware malfunction which needs to be located, otherwise it'll just happen again and again...
Better to find out exactly whats causing it...
  • 3 weeks later...
It's very unlikely that the cause is the Suite software, but more likely the drivers it uses...but again, unlikely because they're written for Sony and you'd certainly hear about - but of course its worth a try uninstalling it.
BSOD is usually caused by a hardware issue, which is why it's best to eliminate as much hardware issues as you can.
This is a fairly old topic, has it been resolved?
