Snaped Axel
trialsmax04
Just snapped my echo 6 speed fixed hub axel. Really really pissed me off as it was only under preload.
Now after scouring the net, i cant find anything sutible. so anyone know where i could find one? If not, can someone reccomend me a DECENT fixed hub for 135mm spacing?
max
Echo Sl's are great hubs. I'm definitely impressed by mine.
They have 12mm axles (most hubs have 10mm, so these are that bit stronger) which is then machined down to 10mm at the dropouts.
Also the cog interface is splined not screw-on, so that elimantes chances of stripping the cogs threads - also it makes it so easy to take off the cogs!
