Brake Help
alex-trials-boy
Hey guys I bought my zoo python 04 the other day and it's awsome I have to say but I put my new TNN's on and when I pull on the brake my god does the frame bow out :( so I want to get a booster but don't know what one to get any help the frame is obv an 04 the brake are 04 maggies and TNN pads (is it a good set up pads are perfictly squear and slaves are all the way out but the pads still rub a tiny bit :( so yea why booster shal I get. Thanks alex.
2 things:
1) What the f**k are you on about?
2) Are any spokes on your rear wheel loose?
he wants advice on what booster to get because his frame is flexing!
and why would it matter if the spokes are loose?
Edit: cant help you trials boy never ran a booster so i couldent tell you
Edited by TOBY-E
Fit a booster that'll help stop the frame bowing and increase braking power. As for the slave cylinders been all the way out that's not a problem. As the pads wear everything will sort itself out.
i saw this bike a few weeks ago, the frames not cracked, it's just not very stiff, get a booster on there asap. the wheels not got loose spokes, and spokes should not be TIGHT... and the setups a bit tight cause at a guess rims werent as wide back in 04 as the echo urban thats in there now :P
Correct amundo. Deng only came out with a wide rim in 05. Booster wise I'd say stay away from 4bolt because then the brake is a pain in the arse to set up.
A good, strong 2bolt (leave the SL shit well alone) is the best compramise IMO.
EDIT: Also could try shaving approx. half a mm off of each pad so it clears the rim no probs.
Edited by CC12345678910
