Removing Double Wall From Single Wall Rim?
Ollied
Bit fiddly and time consuming, but you can get the file in horizontally resting on the lip you want to file (below the tyre bead lip) and file down till its gone, then move round and carry on. Best to get as much out with the grinder as you can.
small thread hijack, but does anyone know how much weight this roughly saves? Toying with the idea myself as i have a spare rim here if it went tits up, just be interesting to see how long one would hold up on the back.
Your front wheel was single-walled by me.
I estimated it saved around 90g?
