Hope Lever Body
lankeman
Im new to hydrolic discs... so...
But i need a right hand lever, will this body work? chain reaction link
Also bleeding kit needed to change? iv always jus drown the hs33 lever in water to bleed (so unsure bout this hope one).. oh and i know its oil.
cheers
Give hope a ring. They won't be able to supply you with anything (unless it's via your local stockists) but they will answer any technical questions quite happily.
I think thats the wrong lever...as the moto takes a different style lever.
The Hope has to be bled with dot 4 or 5.1 ( as it says on the bore cap )
cheers
You could do with a bleed kit for it, you bleed it as you would a car.
Also, don't go giving the brake a bath of mineral oil, and keep the oil off your skin.
im not too sure if running it upside down will work....with it being an open system, would there be a chance of any air rising to the bottom of the reservoir then getting into the lines?
as for a bleeding kit...the only kit you need really is a some plastic tubing to attach to the bleed nipple, and ideally a bit of assistance. takes no time at all to do and is pretty fool proof....
got a mate to help with the bleed situation now.
I put the lever on upside down this evening and filled up with air and went poo!
Can i not just buy a right hand lever that "Craigjames" posted as link?
im a little lost...even after scrolling up and down a few times!?
you have a left hand lever just now...is that a lever you are currently using for your rear (or front if euro) brake?
or is it a lever you already have but are not using....sorry its been a long day!!
the link that alexdark posted is what you are looking for...the hope mini/mono trial lever for the right hand side.
the resovoir cap is NOT cross compatible for between left/right hand levers.
lol, the brakes were euro style when i bought the bike, anyway to be on safe side iv just bought a whole right hand lever :)
