Magura Lever Problems
Ash-Kennard
ive got 2 04 maggie levers. one is leaking through the lever piston. the other is sticky in the lever piston.
someone fix this for me lol i have literally no clue
sounds like the leaky one could maybe use some new seals? and i think the sticky piston could be solved with sanding it a bit, some one correct me if im wrong as i have had some 04 maggies for a couple of years and cant remember much
i had the sticky piston problem the other day mate, take out the piston clean, lubricate and reasemble. if that doesn't work, take out the piston and sand a tiny bit of it, refit and try again. Keep doing this only sanding a very tiny amount of the piston each time until it works. As for lub i have always used gt85
Edited by rab shropshire
