Vtt2
bundee80
Here it is. I've already upgraded the rear tire to a Der Kaiser and have a new front wheel. I may make some other adjustments such as going to front Maguras - but the BB7 is dialed and I have a Hope sitting around too. Definitely new pedals, though. I'm having a hell of a time with the rear Magura mounts not going high enough, so I had to go from Echo TR mounts to the stock ones with the washers. Ghey.
Otherwise, I'm loving it. I was riding a +60 GU before this, and the Meta geo feels pretty similar except lighter on the rear wheel. I don't want to grind the rear wheel, just because it looks stealth, but I'll kill myself if it gets wet.
Thanks to pav for the frame, and props to Tarty for a whole bunch of integral parts. You guys rock! :cheers:
Edited by bundee80
Thanks for the words. I am using snail cams. I had to make some spacers, because the ones that came with the rear hub were too wide and wanted to have them just in case I decide on going back to vertical dropouts. I love the front tire. I do mostly urban, so it works perfect for me.
