26" Frame
Matt Vandart
I think you may be asking for something that doesn't exist?! The new Meta VTT2 is the closest I can think of at 1095, +55 with a disc mount; but I assume that's too long, although you could run it with a fork with less rake. I imagine the TMS Evo is too low and too expensive and you've already said the GU is no good as it has vertical drop outs.
Matt, I've got a frame at home that I brought practically brand new from some chinesse guy. He said it was a Zhi Z2, but it doesn't quite look the same, and it measures up differently.
Anyway its the geometry your looking for : 1075, +60, 383, 72. (with my Atomz forks)
EDIT: Its vertical dropouts, but maybe you wanna try it out and see if its the geometry for you? ^_^, before you go and splash out on a frame that you may not like..
Edited by cai
