Jumping High
Alle.C
Hi guys !
I'm soon buying a new frame, is it better with long chainstays and high BB rise or low BB rise and short chainstays, blah blah blah... :P
sooooooooooooooooo, WHAT DO YOU THINK !? :)
What do ride at the moment? How tall are you? whats your riding style? street/natural? 20"/26"? bothered about weight?
I'm 185cm tall, and weight is around 67kg.(though it's all muscles :P ) and I'm riding the monty kamel 220 frame with ECHO Urban stem (wheelbase - 1000mm. BB-rise - 65mm. chainstays - 362mm )
riding both street and natural
something like that :P
Edited by Alle.C
longer chainstays generally means you can gap further so im assuming its the same for sidehops...
not really
as said before a good technique is all that is needed !
perfect your technique ! and build your bike around it
shorter chainstays will make it nicer on the back wheel
a higher bb will also !
a higher bb you will find things look smaller for things such as sidehops !
so you have a mental advantage
the only thing that will help is loosing weight from the bike !
and improving technique
